Re: Re: Re: Hydra Touch Control Valves
Posted by big fred on January 29, 2001 at 10:46:22 from (12.13.226.18):
In Reply to: Re: Re: Hydra Touch Control Valves posted by Jim on January 29, 2001 at 08:08:30:
If that is the case, it will be obvious when you remove the valve. If the splines in the handle are bad all you need to do is find a handle. If the splines on the valve are bad, you need to replace the shaft in the valve or drill and pin the handle to it. Which you do would depend on whether you can find the parts and how comfortable you feel about taking that valve apart. If you take the valve apart, it is a real good idea to have your Case/IH parts man run you a copy of the parts manual page for that valve. The exploded view will show you how it comes apart and how it goes back together.
Post A Followup
: Re: Re: Re: Re: Hydra Touch Control Valves
