Re: Re: Re: M bore
Posted by Denny Frisk on January 29, 2001 at 11:06:32 from (12.4.181.2):
In Reply to: Re: Re: M bore posted by Steve on January 29, 2001 at 07:03:11:
You mean IH "Fire-Crater" or M&W "Add-Power" don't you? Allis also had something called a "Fire-Crater" sleeve & Piston too. The name had something to do with the dome on the pistons creating a hot spot or "Crater" Dad has the M&W's in his '51 M. Neat Sleeve& Pistons. Wrist pins off-set so the rod gets a better angle on the crack throw, and sleeves are a special material that hold oil better than normal gray or ductile iron. I know that M would sure outpull the Super MTA he had at the time!
Post A Followup
: Re: Re: Re: Re: M bore
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
