Re: 656 Hydro, the perfect tractor?
Posted by Lee K. on January 29, 2001 at 11:25:14 from (205.160.206.85):
In Reply to: 656 Hydro, the perfect tractor? posted by Darren on January 29, 2001 at 10:06:13:
Hydros are good tractors for everything but heavy tillage. I personally wouldn't use a hydro for any plowing. Twenty acres isn't that much, but you won't be able to pull much of a plow with it. It also depends on the type of soil you farm on. On heavy ground, the 656 would probally pull 3-18's or 4-14's. The problem with doing heavy tillage with a hydro, is that the hydraulic fluid gets over heated, and begins to deteriate the hydro parts. I suggest you find a 656 gear drive or a 706 for your heavy work.
Post A Followup
: Re: Re: 656 Hydro, the perfect tractor?
