Hello tractormiallis, When the chain is new, it may yake 2 to 3 times fo thightening before it settles to the proper lenght. My neighbor had the same problem, i adjusted the chain for hi and he cut that day with no problem. Make sure it is getting oil. Take the chain and bar off and make sure oil is coming out of the lubricating hole. The bar has to be clean in the groove for the oil to get to the cutters. Here is my neibor's saw on the bench. Should be close to what you have. Guido.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
