Re: Cen-Pe-Co?
Posted by sotxbill on May 27, 2011 at 07:45:29 from (76.227.27.16):
In Reply to: Re: Cen-Pe-Co? posted by mkirsch on May 27, 2011 at 06:09:26:
actually you can use the over the road trucking industry to tell about oils... although not the same as tractors, they drive around the clock, every day and do 500,000 miles a year in some cases...
and they prove.........
you can get up to a million miles between overhauls...
using any one of serveral heavy duty oils and doing proper oil changes every 10,000 miles on the heavy duty diesels...
but remember tractors can be run much harder plowing constantly and longer or tractors can be run doing trivial tasks like pulling wagons or spraying jobs...
bottom line.. use a good heavy duty oil, change it on time and you dont need all the other crapola...
there are too many examples and tests in the hd trucking industry and real world, verafible results to argue with. the rest is snake oil..
