Depends on the GVWR of the half ton in question. Many '95 or newer half tons will have a higher GVWR than an earlier 3/4 ton will. As for brakes/bearings trans etc for your ocasional use their supposed weaknesses won't be seen. I'll put my 8,000 GVWR '99 Suburban (w/tow pkg/sway bar) against any pre '90,s 3/4 ton. Bottom line is , they are all just pick-up,s with pick-up frames and tires. If you want guarrantees...get a one ton w/duals. Some will say that isn't enough. Buy for your 95% use and for that other 5% use your head and don't go over 50mph and have good 4 whl brakes on trailer. You won't have problems.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
