Re: OT---Strange GFCI Problem?
Posted by farmall300u on September 02, 2011 at 00:12:59 from (70.180.200.57):
In Reply to: OT---Strange GFCI Problem? posted by Jiles on September 01, 2011 at 22:39:30:
I have under cabinet florescent lights running through a GFI and use a wall switch with no problem.
1. I would not tear up a wall
2. On the florescent lights, did you change the ballasts? If not, I would buy one and keep swapping it until the GFI does not trip.
3. Does the GFI trip if only 1 lamp is turned on with the wall switch while the second lamp is off? Then do the other lamp.
4. Check all common and ground connections
