Re: rear wheel drive vehicles??
Posted by dhermesc on February 06, 2012 at 06:13:15 from (24.248.193.103):
In Reply to: rear wheel drive vehicles?? posted by dave2 on February 06, 2012 at 05:05:15:
Automatic or manual? If its an automatic you might want to make sure it has the correct fluid in it or look at a transmission flush. If its a manual and has heavier fluid than it should it probably wouldn't go into gear - but it might.
I don't know about Kia manual transmissions but many other "imports" use automatic transmission fluid instead of 80W like most people are used to seeing in gear boxes. My little Ranger I had used a Mitsubushi 5 speed - it needed ATF fluid but was accidently filled with 80W after a bearing was replaced. It worked fine that summer but once it got cool the oil thickened and it wouldn't go into gear - the tolerances wear too tight for the thicker fluid.
