Tractor Talk
Re: 1954 NAA Ford Tractor
[ View Follow Ups ] [ Post Followup ] [ Return to Tractor Talk ]
Posted by mike on May 26, 1998 at 20:17:51:
In Reply to: 1954 NAA Ford Tractor posted by Larry on May 24, 1998 at 21:31:28:
: The hydraulics on my NAA will lift a post hole digger if I rev up the rpm's but will not hold the digger up. I need to know what to look for and what it will take to repair the hydraulic lift.
Remove the left inspection cover, the one with the pto engagement lever. With the tractor running and with the lift lever in the up position, look up inside at the hyd components and you will probably see where the oil is leaking from.
Post a Followup
: Re: Re: 1954 NAA Ford Tractor
