Re: Categorey 1,2or 3
Posted by paul on March 04, 2012 at 08:43:26 from (66.44.132.109):
In Reply to: Categorey 1,2or 3 posted by luckybodog on March 04, 2012 at 06:50:58:
You have cat 1.
0 is garden tractors, sometimes you can make those fit by adjusting your chains/blocks/let it swing.
1 is common for 20-50 hp tractors.
There is a modified cat 1 for sub compact tractors with short arms, the little 15-20hp fellas.
2 is for over 50 hp tractors, bigger pins, wider frame. A good cat 1 tractor near 50 hp you can probably adapt to fit, change the pins, adjust the arm stablizers, etc.
And so forth, cat 3, cat 3N, cat 4 - gets up to 500 hp tractors.....
--->Paul
