Re: Welding experts needed
Posted by IaGary on April 01, 2012 at 19:48:08 from (108.160.229.48):
In Reply to: Welding experts needed posted by Fritz Maurer on April 01, 2012 at 19:34:51:
I've had pretty good luck cold wire welding cast iron.
Put a grinder to the cast. If you get yellow to orange sparks off the cast it can be welded.
Vee out the crack with a grinder then weld it slow.
By slow I mean weld a 1/2 inch or so and let it cool then go again till you have the void filled with weld. NEVER allow the cast to get hot.
I have welded the exterior of engine blocks this way 3 or 4 times and have not had a failure. One had a slight seep but never a leek.
Gary
