I have 2 Reese drum mowers, one is a 2070w foldback and the other is a 2400 hl hydralic lift. Bought both used and somewhat abused. The simplicity of the machines is amazing.
They cut well, as fast as a disc mower but maybe not quite as uniformly. Mine leaves a few tuffs of grass at the edges but that is most likely my driving. I have a tedder attachment on the big mower that spreads the hay as it exits the mower.
Parts are easy to buy from Tigerco the distributor, but pricy. The manual is the worst I have ever seen, but the mower is so simple it doesn't matter much.
Best part so far is "hook up and mow" versus "hook up and fix mow fix mow"
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
