Tractor Talk
Re: Converting Generator to Altenator system
[ View Follow Ups ] [ Post Followup ] [ Return to Tractor Talk ]
Posted by LANDON on June 03, 1998 at 21:13:43:
In Reply to: Converting Generator to Altenator system posted by Andy on June 03, 1998 at 20:48:39:
: Is it possible (mounting considerations aside) to use a basic 12 volt AC Delco Altenator on the electrical system of a 12 volt JD
: 60? I notice that there is only one wire coming from the NEGATIVE pole of the battery, thgrough the ammeter and to the
: voltage regulator mounted on the current generator. A wire also goes from the same post on the regulator back to the ignition
: switch (seems weird to me but it works). I assume that these wires can be attached to the "Battery" post on the altenator but
: what do the other two terminals (titled simply "1" & "2") attche to? Also, I have heard that there may be some modification
: needed to the coil? Any help on this would be greatly appreciated as I have already started ripping things apart. Maybe there is
: some publication explaining all of this but I know it can be done. THANKS!
Post a Followup
: Re: Re: Converting Generator to Altenator system
