Re: OT Coleman Generator Question
Posted by Bob M on July 09, 2012 at 19:11:46 from (65.110.154.2):
In Reply to: Re: OT Coleman Generator Question posted by Wesley Stephens on July 09, 2012 at 18:52:20:
So long as the generator did not run too long with the armature rubbing it'll simply "shine up" the armature poles and field shoes a bit - there should be no permanent damage. Be sure to blow out any metal shavings, etc. inside however!
A bigger concern is the molded plastic end bell. If the bearing has spun it likely chewed up the bearing cavity which generally ruins the end bell. Unfortunately the only fix is replacement
