Re: Hi Clear tractor with front plows?
Posted by Mark Capps on July 14, 2012 at 15:36:47 from (99.2.100.239):
In Reply to: Re: Hi Clear tractor with front plows? posted by WGWKy2 on July 14, 2012 at 15:20:04:
Hi,
Yes I have looked at the Farmall's but could never get a measurement online for the clearance. The Farmall is what I had in mind with the front plows set up to do the plowing once the ground is fixed with the larger tractor. I would need about 12 inches more than the Ford 601 is giving me.
Mark
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
