I'd be more concerned about the effictive lift you're asking of the pump rather than the simple length of the line. Friction loss does come into play... but when you're moving 6 gpm in a 1" line it's not a big deal. When you're trying to shove 100 gpm through the same line... friction loss IS a big deal. Are you lifting water 5'? 10'? 20'? 5' is fairly reasonable. 20' on that run, with a jet pump... is probably asking for trouble.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
