Survey says---catalytic converter. I had a Chrysler a few years ago that started losing power on acceleration and if you set in neutral and stepped on the throttle, it sounded like you were trying to push a tornado through a keyhole. Due to the converter being stopped up it was leaking around the exhaust manifold and exhaust pipe. It was one of those that had the little springs and bolts that held it together at that point.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
