Re: Long arcing sparkplug
Posted by Janicholson on December 28, 2012 at 20:20:16 from (74.60.94.18):
In Reply to: Re: Long arcing sparkplug posted by 36F30 on December 28, 2012 at 19:21:29:
With respect, the rotor gap is usually in the .005 to .008" range. That gap will let the spark jump to the wire then to the plug. if the voltage is lets say 1500 volts, it will bleed through the insulator fouling to spark plug body easily. I have watched it many times on a Champion spark plug tester. As the voltage is increased by making an auxiliary gap from the ignitor coil in the tester, the weak failed spark along the insulator will leap out and jump the gap of the plug where it belongs. Jim
Today's Featured Article - Talk of the Town: What's The "Stuckest" You've Ever Been? - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I was about 14 (part of the problem) when I got stuck. I was disking with a cab equipped IH 966. The window was dirty and I was driving into the evening sun. It was hard to see and it was my first pass down the field. I got the tractor so stuck that the underside of the tractor was resting on the ground. My uncle wanted ... [Read Article]
