1. 1970 JD 4020 LP Side console, Has to be a 1970 as the other 3 4020s I have are 1970's, with a 2 post rops and canopy SR, 3 hyds
2. JD 4455 MFWD Cab with a 265 self leveling loader
3. JD 4455 Mexican made with a 2 post Rops and canopy.
4. JD 4955 MFWD Cab Decked out
5. White 125 Workhorse With Cab air heat duals
6. Oliver 1855 Diesel 2wd with 2 post rops and canopy
7. IH 1468 V8 with 2 post and canopy
8 MM G1000 Vista diesel all decked out
9. IH 1206 2 post and canopy Decked out
10. Oliver 2255 with a 3208 Cat 2wd with a 2 post and canopy
11. Oliver 1850 for a 5.9 Cummins repower
All above tractors would have duals, the max amount of hyd remotes and would be working tractors and would be all options, I would have countless JD tractors as well but I figured I would list the off brand ones I want to own
Forgot to add the 220 hr JD 4055 on Th I would build a room off my house to put it in. It would basically be in the family room of the house just to sit and look at
This post was edited by sideconsole4020guy at 20:05:40 02/10/13.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
