Re: Open center----Closed center Hydraulics
Posted by Bob M on March 01, 2013 at 19:23:43 from (74.67.191.60):
In Reply to: Open center----Closed center Hydraulics posted by lenray on March 01, 2013 at 18:00:47:
1 - Read the tractor specs, or...
2 - Install a tee and pressure gage in the pressure line between the pump and the control valve. Now start the engine and observe the gage.
An open center system will show 0 psi when the control valve is in neutral (centered), and will read system pressure when the valve is operated against a dead head load - like an unconnected hydraulic coupler or a bottomed-out cylinder.
But on a closed center system the gage will show system pressure at all times the engine is running, regardless of position of the control valve.
