Re: WT? Anyone seen this?
Posted by John T on March 27, 2013 at 06:42:25 from (66.87.0.204):
In Reply to: WT? Anyone seen this? posted by JF in CT on March 27, 2013 at 05:47:04:
As you found, theres the normal resistance between the Hot and Neutral (A GrounDED Conductor) that's the continuous path that produces resistance heat butttttttttttt there shouldn't be a current path from EITHER conductor to the case/frame cuz that means there's a shorting current conducting path and if its as low as around 5 milliamps the GFCI does its job and trips, that's NOT a bad GFCI that's a GOOD GFCI doing its job to save a life or prevent a fire.
Now, ifffffff the heater is equipped with the third wire safety Ground (A GroundING Conductor) which is then effectively wired to the engines case/frame and the coolant in which the heater is immersed somehow (short or leak etc) were to allow 5 milliamps of return current to flow OTHER THEN VIA THE NEUTRAL that again trips the good working GFCI....
SOOOOOOOO as you have discovered any leaks or shorts in a defective heating unit is gonna trip the GFCI grrrrrrrrrrrrr Ive been there n done that, hard to find a good quality long lasting unit.
I as a retired electrical engineer just cant in good faith and conscience recommend cutting off third wire GroundING circuits even in cases where such may or may not (depends on circumstances) allow a device to work, but its your tractor your life and your choice so keep safe best wishes God Bless and good luck.......
Ol John T and all
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
