Re: Cutting a gasoline storage tank
Posted by el6147 on April 01, 2013 at 15:11:24 from (50.124.60.237):
In Reply to: Cutting a gasoline storage tank posted by Josh in Pa on April 01, 2013 at 10:38:51:
It seems the simplest things are so over thought , let it sit with all the openings open, the fumes will eventually all escape and then fill with an inert gas such as exhaust from a diesel and a gas engine will work also and use a sawzall, time is your friend, its not going to all happen in a day or two but over time the gas and the fumes all evaporate.I have welded many tanks with never a problem .if it has just one pine hole repair it after its done purging fumes and reuse .
