I never had much luck with a chain doing that. The tree always bends and then the chain slips up. This thing would appear to dig in more as you pull on it, as well as pulling from the center of the tree (though not sure how much mechanical advantage that grants you instead of wrapping around the base, if any).
Using this thing by yourself is a definite workout though. But hooking it on the tree is the easy part. Just bush towards the clevice, let go around the base of the tree, put the chain on, and then get the tractor in place and go.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
