Posted by buickanddeere on August 12, 2013 at 14:40:52 from (184.151.63.190):
In Reply to: STARTING A DETROIT posted by lenray on August 12, 2013 at 13:08:40:
If tearing into it. Order the detroit Diesel updated N series liners and pistons. Forget about the low compression S series junk. Use C45 orC50 injectors. Install the updated cam follower springs and updated valve springs. Don""t grind the valves, grind and seats and then re-ring the engine and expect an improvement. Grinding valves and grinding seats reduced the compression. Change every bearing. Maintaining oil pressure at idle is vital. There is a seal update for the driven end of the supercharger. Reduces the chance of a lube oil fuelled run away.
Today's Featured Article - Upgrading an Oliver Super 55 Electrical System - by Dennis Hawkins. My old Oliver Super 55 has been just sitting and rusting for several years now. I really hate to see a good tractor being treated that way, but not being able to start it without a 30 minute point filing ritual every time contributed to its demise. If it would just start when I turn the key, then I would use it more often. In addition to a bad case of old age, most of the tractor's original electrical system was simply too unreliable to keep. The main focus of this page is to show how I upgr
... [Read Article]
Latest Ad:
[More Ads]
