Re: 9n tractor
Posted by old on September 22, 2013 at 19:20:38 from (209.86.226.30):
In Reply to: 9n tractor posted by lester parton on September 22, 2013 at 17:54:22:
Oil as in a whole lot or just enough to be seen??? Antifreeze has additives that lube the water pump and that looks like oil in the cooling system. So if just a little bit and no coolant in the oil probably not a problem
