Re: 800 ford won't lift grader blade
Posted by old on December 08, 2013 at 12:49:54 from (209.86.226.59):
In Reply to: 800 ford won't lift grader blade posted by jlanza53 on December 08, 2013 at 11:28:53:
Fill in the blanks please. How cold is it where your at?? You say thick oil which says you may have a seal bad between the transmission and or rear end which means the fluids mix and thick hyd oil does not work well if cold out.
