Posted by Steve@Advance on March 26, 2014 at 17:16:38 from (108.245.66.82):
In Reply to: 4230 John Deere fuel posted by David Parman on March 26, 2014 at 12:55:34:
Are you sure the lift pump is good? If it pumps like it should right after blowing out the lines it's probably not the problem, but worth checking.
Like jdemaris said, pull the stand pipe and clean it out. That should also drain out anything in the bottom of the tank. Maybe give it a stir and flush while you're there.
Depending on what you get out of the tank will determine if the ash is getting in there. I doubt you'll find much, but if you do look for possible entry ways, like around the sending unit or a damaged cap. Unless you get something really nasty out the tank, just a flush should clear it up. Having a radiator shop clean it is pretty extreme, mostly that's for something that has sat with gasoline for years.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
