Re: small engine -- no oil
Posted by LOU from Wi. on May 15, 2014 at 09:20:35 from (184.158.18.204):
In Reply to: small engine -- no oil posted by Chris Jones on May 15, 2014 at 08:10:54:
Chris,
Pour a few drops of oil down the spark plug hole,leave the plug out. Grab a 1/2 heavy reversible drill with a socket that fits the starter nut, crank away until it gets easier,and it should. when easier,insert plug and try to start,hope this works out for you.I've done quite a few.It doesn't always work, it depends on how bad the rod and bearing surfaces are bunched up on the crank. We've even added STP and cam break in lube to the engine oil to get it freed up, just remember to drain and refill with plain oil before giving it back. Did this engine have the low oil sensor on it to help save it?People should really go over a unit before using it, a lot of them don't. We do, hope this helps.
Regards,
LOU
