Re: John Deere 2010 hydraulics wont work
Posted by buickanddeere on June 07, 2014 at 08:17:27 from (184.151.36.227):
In Reply to: John Deere 2010 hydraulics wont work posted by Jake Adams on June 07, 2014 at 08:03:59:
Jake Adams said: (quoted from post at 11:03:59 06/07/14) Yes the lever on the left is pulled up all the way. It is always up because a spring is pulling it.
Is that a factory spring or an added field installed invention? If not designed for it.Holding shifter forks against a collar/gear to keep a work system engaged. That's a short lived temporary limp home mode. Extended operation will wear out the shifter etc.
This post was edited by buickanddeere at 11:38:28 06/07/14 2 times.
