It might help to know what make and model winch you are looking at.I put a Ramsey re8000 on my trailer to load 6000 pound JD crawlers.You might not need 8000 lbs of pulling power for wheeled tractors but they are not that much more expensive than 5000 or 6000 lb models. Most planetary drive winchs don"t like to power out for long as they are working against the brake.Freespooling the cable is a must so make sure the winch you look at does that. Luck,JAinVA
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
