Re: L designation for tires means _______ ?????
Posted by Mike Aylward on June 27, 2014 at 15:19:52 from (209.152.135.126):
In Reply to: L designation for tires means _______ ????? posted by Crazy Horse on June 27, 2014 at 05:27:07:
The "L" does mean low profile. For example, there is a tire that is marked "11L-16" and another marked "11:00-16". They are in no way the same tire. While they both will fit on a standard 16" implement rim the 11L-16 is vastly shorter. It was often used on combine rears and wagons while the 11:00 is predominately used as a front tractor tire but also on the rear of some combines as a taller alternative. Usually, a tire that is marked "L" is designed as a high flotation alternative to a narrower tire while trying to keep close to the narrower tire's height. Hope this helps. Mike
Today's Featured Article - Talk of the Town: What's The "Stuckest" You've Ever Been? - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I was about 14 (part of the problem) when I got stuck. I was disking with a cab equipped IH 966. The window was dirty and I was driving into the evening sun. It was hard to see and it was my first pass down the field. I got the tractor so stuck that the underside of the tractor was resting on the ground. My uncle wanted ... [Read Article]
