Re: set down
Posted by john *.?-!.* cub owner on July 04, 2014 at 06:32:59 from (207.119.227.181):
In Reply to: set down posted by jennifer408 on July 03, 2014 at 19:15:02:
I have gotten old enough that I like the convenience, and trying to get away from a lot of maintenance. I have a smaller very well insulated home, and have geothermal heat, both of which I am very happy with. Just remember, that everything has limited life. Solar cells should last for extended periods if designed properly, but the covering over them will deteriorate with time and UV exposure reducing output. The inverters and regulators should last almost indefinitely if designed properly, but even so will fail occasionally. The big long term expense is batteries. Deep cycle batteries with enough capacity to handle higher loads over a long time are very expensive, and even if well maintained, such as ours at the phone company are, still are only dependable from 8 to 20 years, depending on the type.
