Re: Solar panel for 12 volt fence charger??
Posted by jdemaris on July 29, 2014 at 17:02:49 from (70.209.129.234):
In Reply to: Solar panel for 12 volt fence charger?? posted by Tx Jim on July 29, 2014 at 14:19:13:
third party image
A typical 12 volt solar panel has will read 20-21
volts when there is only a volt meter hooked to it
and no load. That reading is called the "Voc."
The right way to check it is when in full sun,
hooked to a load that draws it's rated amp rating
along with a volt reading. A 100 watt "12 volt"
panel will be able to make 21.4 volts no-load, and
around 17 volts when making 6.2 amps of current at
17.4 volts.
Voc = Voltage open circuit - nothing attached to
the panel.
Vmp = Voltage maximum power - what the Voltage
would be under ideal conditions with the maximum
output current
Imp = Amps maximum power.
