Refilling my Dodge 3500 radiator
Posted by 37Chief on August 09, 2014 at 20:44:55 from (68.8.190.118):
I had to replace the radiator in my 96 Dodge v 10 I use to pull my mowing tractor. While doing it I drained the block both sides. Now the water just sits in the full radiator, and doesn't drain into the block Shouldn't there be a small hole in the thermostat to let the water slowly drain into the block. If I run the engine to get it hot enough to open the thermostat, will it get too hot. Can't remember having this much trouble refilling a radiator. Stan
