Re: tire advice
Posted by Dr. Walt on September 16, 2014 at 09:18:08 from (12.2.223.79):
In Reply to: tire advice posted by rray on September 15, 2014 at 12:50:01:
Those breaks in the rubber are minor; I've had
far, far worse on tires that I've used at highway
speeds. The damage is caused by someone NOT using
Tire Lube when they dismounted the tire & the
mount/dismount bar on the tire machine snagged the
rubber. If you're concerned about those spots
leaking air, it's easily fixed by applying some
black "Liquid Rubber" to those spots (thoroughly
clean the areas FIRST). And if you're still
concerned after applying the Liquid Rubber, put in
a tire tube and you're good to go. I've done this
many, many times on highway tires.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
