Re: It's almost that time of year, blading driveway question
Posted by redforlife on October 18, 2014 at 16:24:09 from (68.234.121.124):
In Reply to: It's almost that time of year, blading driveway question posted by JohnDeereJimOhio on October 18, 2014 at 14:06:07:
If you have recently added alot of rock to your driveway, it is pretty likely the rock is farely loose. I wonder how it would work to use skid plates or pipes as suggested, leaving say a 1/2 inch of snow, and then drag a section of drag harrow over the rock mixing the remaining snow into the rock and working some rock back up to the surface. Once some rock is back to the surface you should regain your traction and not end up with a compacted icy sheet of snow. I think it would work pretty good depending on how loose the rock is. Once the rock gets really compacted, the harrow would likely not do much good. If thats the case, maybe loosen the rock up with a blade or something before the snow flies. Just a thought.
  Upload Photo  Select Gallery Photo  Attach Serial No List
