Posted by JD Seller on October 21, 2014 at 18:50:24 from (208.126.198.123):
In Reply to: O.T. Barn Floors posted by mtjohnso on October 20, 2014 at 19:25:14:
I stored a lot of square hay in dirt floored sheds. I leveled the dirt out and then laid a sheet of heavy plastic down. I then laid 1/2 plywood down over the plastic. The plastic kept the ground moisture out and the plywood kept the hay from sweating/molding from the top. The bottom bales where usually in fine shape.
I liked where I could pickup the plywood as I used/sold the hay. So I could back a trailer/wagon right up to the pile to load. The plastic I usually cut off as I went back into the stack.
I found the best plastic to use is the sheets made to be used as bunker silo covers.
I used pallets a few times. About half the bottom hay would be in poor condition.
If your building a new barn then I would level the dirt out and then spread a good plastic sheet out. Cover than with 4-6 inches of good gravel. Then use plywood right on that gravel to stack the square hay on. The plywood will last years. I would use plywood over chip board. The chip board will not last very long. I have some of the plywood that is over twenty years old.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
