With all the electronics on today's cars looking for a spark when connection the battery will not tell you much. With multiple computers, each one may do a self check when first connected to power and then power down to almost no draw until the key switch is turned on.
I once worked on a 2004 GMC that would have a dead battery every Monday morning after not being used over the weekend. It turned out to be the instrument cluster stayed in the test mode instead of standby. It was supposed to draw about .5 amps when the key switch was first turned on and then drop to a few milliamps after about 30 seconds. To find the problem I connected a ammeter between the battery connection and the fuse panel and then started pulling fuses one at a time to see which one had the major draw. There were several that had quite a draw when first installed but then dropped off when the self check was done. The fuse that powered the instrument cluster and several other things would not power down. It was then a matter of disconnecting the other components powered by that fuse one at a time until the problem was found.
Today's Featured Article - Grain Threshing in the Early 40's - by Jerry D. Coleman. How many of you can sit there and say that you have plowed with a mule? Well I would say not many, but maybe a few. This story is about the day my Grandfather Brown (true name) decided along with my parents to purchase a new Ford tractor. It wasn't really new except to us. The year was about 1967 and my father found a good used Ford 601 tractor to use on the farm instead of "Bob", our old mule. Now my grandfather had had this mule since the mid 40's and he was getting some age on him. S
... [Read Article]
Latest Ad:
[More Ads]
