Re: Transmission Oil level check ..what sort of Oil is suita
Posted by Jason S. on January 11, 2015 at 07:22:49 from (70.197.172.13):
In Reply to: Transmission Oil level check ..what sort of Oil is suitable posted by Bill Fowles on January 11, 2015 at 05:46:11:
Originally it used GL-1 90 weight mineral oil. If you are using it in cold weather then you way want to use 10w30 engine oil so the hydraulics will work faster in cold weather. The GL-1 will work in cold weather it just requires warming up before the hydraulics will work very fast,but letting a tractor warm up in the cold before using it is a good idea anyway. Some say to use modern universal hydraulic fluids but lots of them are not yellow metal safe and the transmission in your tractor has bronze and brass in the transmission. The GL-1 is available at TSC in two gallon jugs. It says Ford tractor mineral oil or you can go to Napa and buy it in five gallon jugs. After draining all three drain plugs under your tractor, remove the bottom bolt where the hydraulic dipstick is. Pour about a gallon in and wait ten to fifteen minutes and pour the next one in. If your pour it in too fast the oil will run out on the clutch and brake shoes. Pour it in until oil starts to run out of the bottom bolt hole where the dipstick is. That is slightly lower than the full mark on the dipstick but it will keep the oil from running out on your brake shoes and clutch from worn seals.
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
