Posted by paul on May 11, 2015 at 08:19:00 from (76.77.197.114):
In Reply to: Treated 4 posted by shunkfarm on May 11, 2015 at 06:54:11:
Hopefully you were or will use bigger than 4x4 for a bigger building.....
The laminated of (3) 2x6 or so posts comes out nice, you need the ground contact treatment not the homeowner cheap treatment.
You can then use the treated laminate below ground, and stager the seams, use regular untreated above ground. Put the money where it is needed, below ground. As well I believe a 2x can be treated easier than a 4x or 6x, so the wood gets treated all the way through in your sandwitch in the ground. As well new wood is weak and knotty and probe to warp; laminated sandwitch of wood is stronger and straighter these days.
The cement column as shown in another message are top of the line, cost more but will last anyone's lifetime. Can even make your own, the key is to realize a pole barn needs a strong pole from the bottom of the hole to the top of the post. You need to make a good strong bracket and connectors so the concrete to wood acts as one piece, not a flex able joint.....
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in
... [Read Article]
Latest Ad:
[More Ads]
