Tractor Talk
Re: Re: Re: Ford 900 electrical problem
[ View Follow Ups ] [ Post Followup ] [ Return to Tractor Talk ]
Posted by Harry on August 27, 1998 at 05:21:31:
In Reply to: Re: Re: Ford 900 electrical problem posted by Rod Carsten on August 26, 1998 at 20:47:04:
I suspect you are right on the amp meter connection. It should reflect what your external voltmeter shows on the battery. I would reverse the connections and see what it does. Your second question about the resistor is a bit vague. You should measure the voltage across the resistor, ie positive lead on side nearest battery and negative lead on other side. The purpose of the resistor is to drop half the supplied voltage. You may just be measuring it wrong. Is your coil a 12 volt coil? Normally the resistors are there to protect the coil not the points. Six volts will drop across the resistor and the remaining voltage across the coil primary. Hope this helps.
Post a Followup
: Re: Re: Re: Re: Ford 900 electrical problem
Today's Featured Article - Show Coverage: Journey to Ankeny - by Cindy Ladage. We left Illinois on the first day of July and headed north and west for Ankeny, Iowa. Minus two kids, we traveled light with only the youngest in tow. As long as a pool was at the end of our destination she was easy to please unlike the other two who have a multitude of requirements to travel with mom and dad. Amana Colonies served as a respite where we ate a family style lunch that sustained us with more food than could reasonably fit into our ample physiques. The show at Ankeny ... [Read Article]
