Posted by Bob on July 24, 2015 at 22:30:37 from (64.255.159.192):
In Reply to: remote valves posted by hendersonmonte on July 24, 2015 at 21:20:55:
Not that plumbing the loader valve into a pair of remotes and tying one of the SCV levers back is the BEST way to accomplish what you are doing, it has been done often and should NOT be causing the tractor's main pump to go "in stroke" all the time.
You have one of two issues... either the loader valve is set up for "open center" (LIKELY), or the SCV you are sourcing oil from has an internal problem (POSSIBLE).
Surf on lower down on the main page to the DEERE-specific Forum.
You'll get lots of advice on how to verify if you have the correct loader valve (or correct changeover "plug" in the valve for closed center) and have to plumb directly into the high pressure source and return the oil to the filtered main pump charge circuit.
The LAST thing you want to do on a closed center DEERE is to return the oil to the "reservoir", that's why you need help from DEERE-familiar folks.
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
