Posted by IHplankton on September 10, 2015 at 14:03:32 from (72.70.233.226):
In Reply to: Water in diesel posted by rrman61 on September 10, 2015 at 11:13:03:
I run a 94 f350 7.3 and my buddy runs a 97 f250 7.3 both of our trucks just died from water in old diesel, (pumped out of a 50 gallon drum from a while ago) got em running real quick doing this:
Drain the water out of the filter if you have water in the lines pull the return lines off the pump and crank the engine to purge the lines. If you haven't run it with water in it, pulling the beds off these is real simple, front tank is easy as well if you leave the bed on.
Depending on how much water is in there you can run it and just crack open the drain on your filter every time you use it, if you get too much water in there pull of return lines purge and refill fuel filter with clean diesel she'll go
You can always shove a tube down the filler and siphon the tank you can get most of it like this
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
