Grinder/mixer tank windows
Posted by DLMKA on September 12, 2015 at 13:23:38 from (99.155.19.247):
when using a grinder/mixer without scales and using the chart on the side and windows in the tank to judge how much feed do use use the feed level when running with the feed piled up higher around the sides or do you try to level it out somehow? Probably a couple hundred lbs divergence between running and leveled out if using the chart and marks on the tank.
