Re: need help on 4020 John Deere
Posted by Janicholson on October 08, 2015 at 20:16:51 from (63.152.202.221):
In Reply to: need help on 4020 John Deere posted by haley on October 08, 2015 at 17:45:31:
Not knowing the engine, but with a formerly useful idea!
If the passage from the hole in the rocker shaft support in the head is a straight drilling to the cam bearing (probable), the use of a thin brazing rod to probe down the hole,while very slowly turning the engine by hand, will allow you to feel the cam journal aligning with the hole. If it will not "find" the hole, expect a spun, or improperly installed cam bearing.
You could also blow air down the hole and listen for a change in flow when the holes line up. Jim
  Upload Photo  Select Gallery Photo  Attach Serial No List
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
