Not normal! I would have a good look at the grounding of the alternator. Or jut for insurance add one to the block. Voltage regulator depends on a good ground to work properly. Bad ground at the alternator will make it go goofy. With new batteries they should be able to load test the alternator as you said. Could be just a bad regulator. How many are there in the system 3? If you are consistently operating at zero degrees a fourth one may be in order.............
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
