Re: Wanting to build a welding fumes exhaust vent-any ideas?
Posted by PJH on January 10, 2016 at 23:19:23 from (172.79.181.20):
In Reply to: Wanting to build a welding fumes exhaust vent-any ideas? posted by Alan K on January 10, 2016 at 22:37:06:
I have an attic fan in my shop for summer cooling. I'm sure you know how they work, drawing a vacuum in the room and exhausting into the attic and on outside. I can't run it all the time in the winter, of course, but I can bump it on for 30 seconds and clear the shop of all smoke (after cracking a window open). The heat goes out with the smoke, but my shop furnace burns wood, and it recovers quick and cheap. I don't weld right under it, so in the summer it works nice to leave it on and it pulls the fumes away. Winter, not so nice to leave it on, ha. Shop is small, about 30 feet X 30 feet.
Any time you pull a vacuum inside a building, there's danger of pulling fumes back down your chimney. A wood furnace will let you know quickly that you need to crack a window open, but I'm not sure you'd notice a problem with a gas furnace as quick. That being said, a fresh air intake designed to work with your exhaust would be necessary if your shop is tight.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
