Re: Update on 1994 Ram 1500 brakes
Posted by IA Roy on January 12, 2016 at 21:49:32 from (72.168.161.53):
In Reply to: Update on 1994 Ram 1500 brakes posted by IA Roy on January 11, 2016 at 20:38:13:
Thanks for all replies. I have things to check now.
Adjusters were disassembled and lubed with anti-sieze. All other parts in rear were either cleaned or replaced with new. "Determined", I will have to pull the drums to check the linings. I did verify that the steel shoe frames were identical, but didn't pay attention to see if the new linings are all the same or different. I just went out to the garage to look at the core linings, and can't tell where the linings ended as large parts missing and rusty. Drums were not machined or replaced. No apparent damage, probably the best looking ones I have seen in a long time. "Super H" I will check on your suggestions, almost positive 4 wheel ABS. "Marlynr" Calipers were not removed, only worked on the bleeders to free them up. They are on top. T in NE. This is a 94 Dodge. The rear brake technology is 70's. There are two types of self adjusting drums. This type has the adjusters clear at the bottom and are activated by a lever that pivots off of a pin on the rear shoe. There is a newer design where the adjuster is above axle center and is connected with the parking brake cable. "Steve: hard pedal ineffective, sometimes locks one front wheel when chattering. Previous to working on it this winter, it did not ever lock up.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
