Re: Head scratching problem???
Posted by ditchwitch on March 01, 2016 at 06:31:08 from (98.101.210.114):
In Reply to: Head scratching problem??? posted by JD Seller on February 29, 2016 at 18:31:01:
JD, Has anyone checked this car for a draw. Very well could be something drawing the battery down. Sometimes it takes a while to find the culprit. You just have to catch it when the mill amps are spiking. Could have a module waking up causing the draw. We had one here and finally found out it was a seat motor causing the problem. What we do is open all the doors and trunk and hood and manually lock them.Car thinks everything is shut. Hook the meter up and see what the mill amps are after about an hour then just keep watching it after that and see if you can catch it when its spiking. And if you catch it start pulling fuses till it drops soon as it does check and see whats on that circuit.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
