Re: BREAKING IN A NEW ENGINE
Posted by BushogPapa on March 11, 2016 at 07:24:22 from (107.10.186.248):
In Reply to: BREAKING IN A NEW ENGINE posted by GENE DERRINGER on March 10, 2016 at 16:33:02:
Engine should be put under at least a 50% Load within 20 Minutes of the 1st start-up..and 50 to 90% RPM..do NOT Labor the engine (stay 1 gear lower than Maximum Load)..
IF you run it longer than this Idling, the Cylinders will Glaze and the New Rings may NEVER Seat..
Vary the load often and run the tractor until it has Completely Heat-Soaked the entire engine.. at that point, it is READY for Re-Torque and re-set the Valve Clearances..
Change the oil (or at least the oil Filter) after 16 to 20 hours of operation..
Ron..
  Upload Photo  Select Gallery Photo  Attach Serial No List
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
